Go to solution Solved
Hdmi input setting for sound bar
(Topic created on: 07-12-2021 03:18 PM)
Edgie70
Hotshot
Hi all , on your TV for those that have a sound bar connected via HDMI arc , what do you set your hdmi input setting to ??? Pcm or bitstream ???
Pugs1957
SuperStar
12 REPLIES 12
xSteveuk
Samsung Members Star ★
Hi,
This page maybe helpful
Change the audio format on your Samsung TV
https://www.samsung.com/us/support/answer/ANS00085244/
Pugs1957
SuperStar
JAMES4578
Samsung Members Star ★★★
I use Bitstream, as is explained in the article @Pugs1957  the quality will very much depend on your particular system.
Edgie70
Hotshot
Hi @JAMES4578 I have a Sonos beam gen 2 and 2 One SL surround speakers connected via HDMI to my Samsung nu437400 TV
JAMES4578
@Edgie70 Think I would go with Bitstream, you may wish to make a  comparison though.
Anonymous User
Not applicable
Probably bitstream if you are using external speakers. But every person's taste is different, so try both of the settings and see which one you prefer.
Anonymous User
Not applicable
What is your audio output set to ?
Edgie70
Hotshot
It was set to pcm but not it's set to bitstream
Edgie70
Hotshot
It was set to pcm but now it's Dolby digital
