17-04-2022 08:13 PM - last edited 17-04-2022 09:20 PM ) in
WearablesSamsung Galaxy Buds Pro are not noise cancelling as adequate. instill hear noises from oitside. I use the buds with their LARGEST fittings, i already have AIRTIGHT seal, i feel TIGHT fit in my ears.
as seen on the screenshot, the settings are CORRECT. Samsung, please fix and update the software of the buds. The current software of rhe buds is not noise cancelling adequatelly.
Solved! Go to Solution.
18-04-2022 01:47 PM in
Wearables17-04-2022 09:02 PM - last edited 17-04-2022 09:05 PM ) in
Wearables17-04-2022 09:23 PM in
WearablesI believe, they are halfway done, because they are given for free.
17-04-2022 09:28 PM in
Wearables17-04-2022 10:09 PM - last edited 17-04-2022 10:13 PM ) in
Wearables18-04-2022 09:36 AM in
Wearablescan you provide a link to these?
18-04-2022 09:41 AM in
Wearableshello, what i expect is Samsung to keep its word. of Samsung says 99%Noise canselled for this model, i expect to receive exactly what is promised for this model 99% noise cancelled, why i have this expectation? Because I am promised exactly that.
18-04-2022 12:50 PM in
Wearables18-04-2022 01:47 PM in
Wearables18-04-2022 04:29 PM in
Wearablesi never asked about 100%, never asked about 99,9% but it is promised by samsung and samsung is failing here. i never asked for 99%, i asked for lower then promised. i asked for 90% noise cancellation, and i have reasonable expactation for 90% when i am promised 99,9% noise cancellation by samsung, how is my expectation unreasonable when i am asking for less than i am promised?
