Go to solution Solved
Gear s3 or Gear s4?
(Topic created on: 06-06-2019 03:38 PM)
DAZ5
Hi all..I have the gear s3 frontier watch but forget pin..I have spoke to Samsung & had no joy just saying an engineer will have to look at it on live chat..is there a factory setting pin I could use ?
SjorsK
Maestro
Nope, but a factory reset is an option:
Hard reset (experts only)
If you forget your screen lock PIN, you can perform a hard reset and restore your device to factory settings. Your personal information cannot be recovered after using this feature.
1: Turn off your Gear S3.
2: Press and hold the Home key until REBOOTING displays at the bottom of the screen.
3: Press the Home button repeatedly until the Select REBOOT MODE screen displays.
4: Press the Home button until Recovery is selected, and then press and hold the Home button.
5: Keep holding the Home button until the Gear S3 begins rebooting.
Source:
https://www.samsung.com/ca/support/mobile-devices/gear-s3-frontier-how-do-i-reset-my-samsung-gear-s3...
3 REPLIES 3
SjorsK
Maestro
Source:
AndrewL
@DAZ5: If you have set your own personal PIN then the default PIN will not work unfortunately. I recommend visiting a Samsung Support Centre with a copy of your proof of purchase, and an engineer will be able to assist you further. To find your nearest one please check the following link, select 'Mobile Device > Phones, Tablets and Wearables' and enter your post code.
http://www.samsung.com/uk/support/servicelocation/
Yogi2
Done that didn't work
