Go to solution Solved
GA2 Chirping Notification Sound
(Topic created on: 19-11-2020 05:24 PM)
RaCheyl1
So I have a Galaxy Active 2 watch. & I've set my notification sound to "SKY" but the only time I hear that sound is when I get text message. So all my other notifications (Gmail, Tik Tok, Facebook ect) are all coming with a "CHIRPING" sound. Is that how it's supposed to be? Is there a setting I can change ALL notification sounds to be set to "SKY"?!
RaCheyl1
I fixed it! I read on a reddit log that if you have the notification vibration set to "echo" than it's kind of a little system bug malfunction with that vibration. So you have to set the notification vibration to something different. Then the specific notification sound you want set from the drop down menu will automatically be set to ALL incoming notifications. So it's fixed! & works for PERFECTLY.
2 REPLIES 2
AndrewL
@RaCheyl1: That's strange. On the watch itself if you head to Settings > Sounds and Vibration > Notification Sound, and set this to Sky, then open the Wearables app on your connected mobile phone and check the notification sound here, is it also set to Sky? Do any of the affected third party apps have a custom notification assigned to them on your phone? If so, try changing this to one of the default options via Settings > Apps > Tik Tok (as an example) > Notifications > General Notifications > Sound.
RaCheyl1
