15-01-2020 02:29 AM in
TVHi. I'm having trouble using my AirPods with my Samsung smart tv. The volume is so low on my AirPods that's its impossible to hear anything that's playing. I have the 7 Series smart tv and I know it's Bluetooth compatible. I've tried disconnecting My AirPods. I've tried deleting the AirPods from the Bluetooth list and reconnecting them and that did not work. I've tried holding down the power button on my remote to reset the TV. That did not work. I also connected my Bluetooth speaker to the tv and was able to adjust the volume using the remote or the speaker itself, but not having any luck with my AirPods. I've tried calling samsung tech support but the lady I spoke to didn't have a clue as to why I couldn't adjust the volume. Someone please help me
18-01-2020 09:19 PM in
TVi have the same problem, did you found a solution ? I've tried almost everything without success
18-01-2020 09:48 PM in
TVSame here. I've tried everything I could think of and I haven't found a solution. I've been reading that it's a Samsung system problem and only they could fix it which is annoying. My LG tv worked well with my AirPods
18-01-2020 10:12 PM in
TV18-01-2020 11:00 PM in
TVYou're welcome and I absolutely agree
15-03-2020 09:20 PM in
TVSame problem! Also AirPlay isn't working either. Why didn't bought a LG instead? WHYYYYY?
24-03-2020 03:21 PM in
TVSame issue. These are the kind of things that will make you question whether you should ditch this whole smart TV nonsense and just buy a set top box like Apple TV
27-03-2020 01:33 AM in
TVI HAVE THE SAME PROBLEM AND IT'S REALLY ANNOYING.
EVERY SINGLE OTHER DEVICE WHERE I USE THEM WOKRS PERFECTLY BUT MY TV.
SOMEONE FROM SAMSUNG PLEASE HELP US!
03-04-2020 05:36 PM in
TVsame here! Samsung say something! do a system update, it's embarrassing. There are milions of airpods out there!!
03-04-2020 11:53 PM in
TVPlease SAMSUNG send us the update we need!! I have air pods and Bose speakers and same problem in both :(( No way to use them on the TV
