Go to solution Solved
Samsung TV picture flickering on certain channels
(Topic created on: 14-01-2020 10:56 PM)
Blomas
Hi I have a Samsung TV model no LE32B450C4W recently certain channels have started flickering for example itv, Channel 4, Channel 5 and itv2 I've tried redoing the aerial connection and power supply out for 5 mins any help would be appreciated thanks
Barry
Blomas
Hi SaudA thank you very much it seems my amazon firestick was interfering with it so I've moved it to another port and upto now alls well again
Thank you Barry
4 REPLIES 4
SaudA
Troubleshooter
Hi @Blomas
Do you have any external devices connected to the TV? If so, can you try disconnecting them and see if this helps? Could you also try this hardware test, and check if you get the same issue there: Menu > Support > Self Diagnosis > Picture test.
Let us know how you get on.
Blomas
Thank you Barry
SaudA
Troubleshooter
No problem, glad that's sorted! Give us a shout if anything changes.
drmvsrinivas
When i clicked firestick icon screen started flickering.
Later it by itself came to normal.
