Support
Open search
Volume using AirPods with Samsung smart tv
Highlighted
Hi. I'm having trouble using my AirPods with my Samsung smart tv. The volume is so low on my AirPods that's its impossible to hear anything that's playing. I have the 7 Series smart tv and I know it's Bluetooth compatible. I've tried disconnecting My AirPods. I've tried deleting the AirPods from the Bluetooth list and reconnecting them and that did not work. I've tried holding down the power button on my remote to reset the TV. That did not work. I also connected my Bluetooth speaker to the tv and was able to adjust the volume using the remote or the speaker itself, but not having any luck with my AirPods. I've tried calling samsung tech support but the lady I spoke to didn't have a clue as to why I couldn't adjust the volume. Someone please help me
73 REPLIES 73
Highlighted
I ve the same pb with Pro. But only since 1 month.
The remote Don’t have any control to raise.
I’ m french. Sorry for my english
Highlighted
Highlighted
Yes this works for me, thanks!!! Just sad that I can’t control the volume from the TV directly.
Highlighted
Oh good to hear! What have you done exaclty? are you using AirPods pro too?  TY
Highlighted
Hi
yes AirPods Pro
Highlighted
I think so
Highlighted
Try reset your Airpods and pairing to Samsung TV. It worked for me!
Highlighted
@MirandaP24 wrote:
Before you connect to your tv, do the following:
1. connect your AirPods to your phone
2. make sure you have Siri connected to your AirPods (example, if you say Hey Siri, your AirPods will summon Siri)
3. Tell Siri to lower/raise the volume
4. you can always double check this by checking the phone volume on the AirPods.
5. Once you lower or raise volume of your AirPods through your phone you can disconnect them from your phone and connect them to your Samsung tv.
That should work, I just did it myself.
good luck :smiling-face:
This works for me. I still can't control the volume from tv but at least after I increased the volume while it was connected to my iPhone or MacBook, then only I connect to the tv.
Highlighted
Hi. I tried the trick of connecting them to my phone and then setting volume to 100% in which they were already set to that and then connecting them back to my tv but that didn't work... idk what to do now.
Samsung, for God sake, please say something. This is so f**king annoying
Payibg this much for a tv and having this tiny makes me wanna just say the hell with Samsung period
Highlighted
Hi don't work with Pro !!!!
i try All is possible, now only Samsung can do something
Top Liked Authors
