25-07-2020 04:33 PM in
Hi I wanted to know if there is a voice activated TV that allows you to change channels and volume without having to press any buttons. This is for a person who can only communicate using their voice and do not have the ability to use a remote control.
26-07-2020 05:47 AM in
It does appear that such Televisions exist @Rons10
From Samsung smart-tv-voice-recognition-faq.
And sites such as https://www.currys.co.uk/gbuk/samsung-f8000-1322-commercial. which is a Uk site Samsung Tv's such as the Samsung F8000 LED TV have this option although this model now appears not for sale.
I would suggest to speak direct with your local Samsung Experience Store if you have them where you reside or speak to your countries Samsung Support Department or a Google Search may yield results.
🌈 Stay Safe & Stay Alert. 🌈
Daily Driver > Samsung Galaxy s²³ Ultra 512Gb in Phantom Black.
I'm here to help. " This is the way. "
