Crystal iSmart 4K Ultra HD Smart LED TV UA55CUE60AKLXL will support voice assistant
(Topic created on: 18-01-2024 02:18 PM)
Crystal iSmart CUE60
Hi,
Is it possible to enable voice assistant  in Crystal iSmart 4K Ultra HD Smart LED TV UA55CUE60AKLXL  with CUE70 voice assistant smart remote?
Or will the CUE 70 remote which having voice assistant work for CUE60 ?
Please let me know if nayone has any idea
1 REPLY 1
Krystian101
Navigator
If the remote has integrated microphone button you should be able to use voice assistant, you can go to the store apps on your TV to select voice assistants
