Use of timer function does not work
(Topic created on: 30-01-2017 08:50 AM)
I have this problem too
100gasman
Model No UE32K5600AK
I have been using the timer as an alarm in the mornings
two weeks ago it stopped working.
It was set as
Mon  - Fri
06.30am
DTV
Channel 3
All other functions work ok
is it a software problem, can it be rectified, i waqnt this facility
Paul
1 REPLY 1
AntS
Hello @100gasman. :smileyhappy:
What's the current software version you've got on the TV? Settings > Support > Contact Samsung.
Also, is the alarm still showing as being set up at that time? Is the general time on the TV okay? And can you clarify if the source you've set it to is a set-top box or through the TV's own tuner?
