UE55 KS7000 Screen fault 2017-2021
(Topic created on: 06-03-2021 09:27 PM)
Ericaangela
NEVER BUYING SAMSUNG AGAIN.
6 REPLIES 6
Ericaangela
Shazzkid
Troubleshooter
Okey...
AndrewL
@Ericaangela: Sorry to hear that you're having some issues with your TV display. Is the issue present on all channels and sources? If you power off the TV, unplug it at the wall for around 30 seconds, then plus it back in and turn it on using the remote, does the issue persist? If so, head to Settings > Support > Self Diagnosis > Picture Test. Does the fault appear in the sample image, and do you get any 'Failed' messages in the summary at the end?
Ericaangela
Yes have done it all, the diagnostics failed 3 times, it says to call Samsung call centre, but there is no way I’m putting more money into this television.  I have seen this same exact problem all over the Samsung forums and other tv sites.
Members_fndwnfa
Hi, I have the same problem with my ks7000 (60"). Contacted Samsung but it was just (few months) out of waranty so they wouldn't help me. I thought I had the right to many years of joy by buying a 1500€ TV.
I own and have owned many Samsung devices. TV's, monitors and samsung mobile phones starting from before the smarthpone era. This seems of no importance to Samsung though. Too bad.
Members_fndwnfa
found a solution?
