TV switches off and on every 3 to 4 minutes
(Topic created on: 15-03-2017 08:25 PM)
SammySung
6 REPLIES 6
KellyM
Helping Hand
Hey @SammySung,
What model of TV do you have?
Any luck if you disconnect everything (including the internet) from the TV and test it alone?
Gashead
At risk of sounding like Roy from The IT Crowd does the problem persist if you switch off, unplug from the mains, leave for 10 minutes, plug back in and switch on again?
JordanH
Pathfinder
Roy's right, @Gashead
Sometimes turning your TV off and on again can solve the issues.
Did this work?
What model TV do you have?
Can you try disconnecting the TV's power cord from the power outlet and leave it unplugged. Then press and hold the power button on the TV for 10 seconds. After you have held the button for 10 seconds, let go then try to power the TV on.  :smileyhappy:
singh2
I have the same problem and my TV model no. is UE55F6770SSXZG. I tried what you suggested but it doesn't help.
paul1277
Black Belt
The tv is faulty. It should work and if not get it repaired or get a refund.
Paul
singh2
How do I get it repaired? Can I get a technician from Samsung itself.
