TV Standard Remote Record Button Absent
(Topic created on: 13-07-2022 05:14 PM)
daftfish
Hello I have a AU7100 65. I have 2 remote controls with it. I don't like the 'smart' remote so am using the regular version. It is the version which has direct link buttons to Netflix and Prime on it. I use a Sky HD box and can't for the life of me work out how to record a programme with this remote control, can anyone help. I don't want to use the smart control or the sky remote. Surely there should be a way to record the sky box with the standard remote. Any help grateful received.
4 REPLIES 4
Pugs1957
SuperStar
That won't work. The Samsung remote is designed to control the TV only.
daftfish
It's supposed to be a universal control! Previous iterations of the standard remote had a record button.
Pugs1957
SuperStar
Sorry, I didn't realise you meant the universl RC. Are you able to record using the TV guide ie highlight a program and hit select, record?
daftfish
No, that only sets a reminder for the selected show.
