TV Guide only available on Smart remote control - QE65S95B TV
(Topic created on: 30-11-2022 01:07 PM)
MONICA2022
I have a QE65S95B Samsung TV. Samsung support informed me today that the TV Guide is not available through the standard remote control. Only by short-pressing the Smart remote's Channel button. How silly is that?! Listen Samsung UX: The TV Guide should be the most prominent button of the standard remote! We use it all the time.
3 REPLIES 3
JAMES4578
Samsung Members Star ★★
Hi @MONICA2022  Point taken however many customers prefer the Smart Remote  with modern Devices. The standard Remote will have its fans though.
Ginga_p
Hotshot
Maybe the ability to remap the streaming buttons on the the remote atsome point might do the job. Especially with the amount of streaming services available available via the apps
G G
Wombat123
I recently bought a QN95B (Neo QLED) which has a similar issue.
After some experimenting with the standard IR remote, I found that if you PRESS-AND-HOLD the "CH LIST" button the electronic program guide appears.
Hope this helps our S95B fwends.
