02-02-2023 04:52 PM
I’m having a problem with my new remote, my TV is brand-new bought in 2021 and has the Disney+ app on it, I bought this new remote yesterday and it has a Disney+ button on the remote, but when I click it it does nothing it doesn’t connect.
The Netflix button, Amazon Prime button and everything else is working fine.
But for some reason when I click Disney+, there is no reaction at all that infrared is working when I press it.
The infrared is working when I press it, I checked it.
Can anyone think of a reason why this wouldn’t work?
#Disney+
06-03-2023 08:49 PM
Did you solved the problem?
17-05-2024 07:35 PM
I specifically bought VGTM1240AN/XC to use the Disney+ button for my QLED TV.
It clearly says to be compatible with all QLED TV's. Every button works except Disney+.
I've emailed the support and they don't have a good answer for this issue.
I also asked them to escalate the issue to maybe update the TV's software.
I'm wondering if this issue lies on Disney+ or Samsung?
20-06-2024 04:54 PM
Having the same issue , any response from Samsung?
19-07-2024 06:54 AM - last edited 19-07-2024 06:55 AM
I have this exact problem. Any solution?
19-12-2024 09:44 PM
Still no updates on this issue? I too bought a new remote for my 2021 QN90A. The included remote had Netflix, Amazon Prime and Rakuten TV, the new one replaces the last one with Disney+ and Samsung TV Plus (it has an extra button). While on the Samsung TV Plus button the TV shows a pop-up "Not available", on the Disney+ button it too does nothing.
I was researching this already with my older remote, seeing if I could remap the unused buttons but to no avail, I assume this is the same story.
