tv mirroring with galaxy A41 ,which cable do i need ?
(Topic created on: 03-10-2020 11:40 PM)
warby1
just purchased a galaxy a41 and want to connect to a smart tv via hdmi without internet connection ,i,e using a cable ?can you advise which cable is compatable .
1 REPLY 1
AndrewL
@warby1: It is only possible to mirror your Galaxy A41 to a compatible Smart TV wirelessly using Smart View in the Quick Panel or the SmartThings app. This may also be achievable using a third party UBC-C to HDMI OTG cable, however I'm unable to recommend any options.
