13-03-2022 08:21 PM in
Hi, I bought a new TV a few months ago, and set up the apps and wifi to work, but couldn’t get the terrestrial/Freeview TV to work. It is just finding 128 Samsung channels, 0 digital TV channels, 0 radio etc.
It is a UE32T5300CKXXU
The manual tune option is greyed out. I have run autotune about 30 times predominately with the settings as a terrestrial aerial and digital channel type, but I have tried all variations. I have a wall aerial, but I assumed it was broken (new house!) but having bought another aerial it is still doing exactly the same thing - 0 channels.
I have tried a force reset of the TV and it is still finding nothing.
We are 1.1 miles or so from the nearest broadcasting tower.
What can I try next?
Thanks for reading
Solved! Go to Solution.
23-03-2022 08:02 AM in
13-03-2022 09:00 PM in
Couple of things to check before you blame the TV.
you say "New House"... Is there a Signal Booster/Splitter installed in the house? most boosters and splitters are powered.
Have you tried another TV on the same ariel point? Do you get the same results?
Do you have another Ariel point in the house you could try?
This is just process of elimination.
Good luck
13-03-2022 11:26 PM in
Check if there are any problems with Freeview in your area https://www.bbc.co.uk/reception/problems-freeview-reception/#/Freeview other options are to try the Automatic scan again. Some customers have found that scanning after removing the aerial and then reinserting provides a solution when channels are missing and you manual tune may be accessible. In other words scan with the aerial removed when obviously no channels will be found, however this can reinsert the connection. You would then need to scan with the aerial connected again and see if this makes a difference.
However there is the possibility that there is some issue with the aerial. some good advice re Booster and other points by @Sir-BoBaLoT See some more information here https://www.freeview.co.uk/help/reception-picture-and-channels-troubleshooting-guide
One Ui 5.1,Android 13 .
14-03-2022 01:34 AM in
16-03-2022 09:03 AM in
Unfortunately the only other TV (living room) is wall mounted and too big for me to get down by myself. It’s also hooked into virgin cable and given how incapable I seem to be with this aerial issue I m nervous of retuning it and losing the channels on that one too!
It is a new house to us, but the house itself is 1930s. The extension the TV is going in is however 15 years old.
should I be looking for a splitter somewhere?
the new aerial I bought is an indoor one, the one4all SV9436 amplified HDTV indoor aerial. It has a range of 15 miles from a tower nd we are just over 1m and tower I functioning perfectly.
If it were poor reception would we not find channels but not many or not clearly? At the moment it is literally not finding anything.
I don’t think we have any other aerial points, but I will have a look.
Thanks
16-03-2022 09:06 AM in
Hi, it’s indoor, but given the short distance to the functioning tower surely it should work? I bought the one4all sv9436, which was marketed as working within 15 miles of a tower.
also, would I not at least get some channels with poor reception rather than absolutely zero? Or does it not work like that?
Thanks
22-03-2022 08:56 PM in
22-03-2022 10:07 PM in
Thank you. I did manage to figure out that plugged into an aerial I found in another room the TV worked perfectly, so it is the aerial in the wall that’s faulty and the indoor aerial I cbought is clearly not good enough. Do you have any recommendations for an easy to attach external aerial? Or is it worth trying to get an electrician (?) to look at the faulty aerial in the wall?
Thanks
23-03-2022 11:04 AM in
