19-03-2025 08:40 AM
If you have a brand new Samsung TV be aware that it will not receive any ITV channels on its freesat tuner.
This is because ITV (and others) have changed their freesat frequency and symbol rate from 23000 to 27500. Until Samsung understand this problem and fix it with a firmware update, you will not be able to watch 25% of freesat TV channels.
I am about to return my TV for a refund as it is not fit for purpose. Unfortunately you cannot tell which sets are affected until you plug them in and try them!
Solved! Go to Solution.
19-03-2025 05:15 PM
FIXED !!!
Samsung software update installed and seems to have done the trick
21-03-2025 10:27 AM
Also IMPORTANT!
ITV is transmitted on 11344 H from astra BUT
other channels are on 11344 V from astra
Check your lnb skew! else they will interfere with each other
19-03-2025 09:28 AM - last edited 19-03-2025 09:30 AM
19-03-2025 09:38 AM
Yes, I could buy a separate Freesat box as the TV tuner doesn't work, but I bought a new TV with a tuner built in!
19-03-2025 09:49 AM
19-03-2025 10:27 AM
Good idea. But I just want to watch Freesat TV. Many channels are not available online. eg Talkingpictures TV.
I just want my new Samsung TV to work properly!
19-03-2025 05:15 PM
FIXED !!!
21-03-2025 10:27 AM
Also IMPORTANT!
