07-02-2025 11:02 PM
Hello.
I have a 75QN85D model located in Greece.
I try to scan satellite channels through my twin LNB.
Hotbird channels are received well, on the other hand ASTRA 19.2 channels i do receive just around 10(out of the couple hundreds available).
Do i need to reset transponders in order to receive ASTRA 19.2 channels, any idea the settings/transponders required?
Many tnx!!
08-02-2025 10:36 AM - last edited 08-02-2025 10:39 AM
08-02-2025 10:38 AM - last edited 08-02-2025 11:57 AM
08-02-2025 04:12 PM
Thank you for getting back to me.
Yes i have that set up. A dual LNB. I might have phrased it wrong.
So i receive two signals thats for sure, as both signals of the dual lnb, reach the end of the cable. I have measured this with the pediometer(field strength meter if the terminology is correct).
But when connecting tye Ffis cable to the tvs satellite receiver, the tv scans couple of hundred hotbird channels, but very very few from astra(about 10-20max)
Its a software issue of the tv, not a hardware issue from my understanding.
08-02-2025 04:15 PM
08-02-2025 06:21 PM
Thank you Very much .
