Sound cutting out intermittently on 2020 Frame TV with connected soundbar
(Topic created on: 16-11-2020 04:52 PM)
poprock
I have the 2020 55" The Frame TV, and a Sonos Arc soundbar. I have the soundbar connected via HDMI ARC.
When I first switch on the TV, the sound is intermittent. It plays through the soundbar for a few seconds, cuts out for a few seconds, plays again, cuts out again, etc.
Disconnecting and reconnecting the soundbar usually fixes it. But that’s not really good enough – I need a permanent fix.
With the TV menu bar open, I can see the sound source auto-switching back and forth between HDMI ARC and just HDMI. When it says just HDMI, there’s no sound.
Any ideas? Has anyone else seen this issue?
48 REPLIES 48
poprock
Have you applied all the latest firmware updates?
My Frame/Sonos setup via eARC works perfectly since the most recent updates to both. All problems solved.
DustinT
Yes, I have been running the Samsung firmware posted from late April and Sonos app claims there are no updates available.
I still have the issue. My workaround is to not power off the TV but let the ambient settings sleep the TV when no motion is detected.
coolbips
QUICK WORKAROUND:
No need to reboot the devices or unplug the cables
Goto Settings -> Sound -> Sound Output
Change from HDMI - eArc to TV SPEAKER
Once the sound is working on TV speaker, switch it back to e-Arc and it should work.
Give a thumps up if this works so that others can follow.
MJP123
Hi
thank you but this doesn’t work for any length of time before it cuts out again. Samsung have basically acknowledged that they do not have a solution to this problem.
This appears to be a straightforward compatibility issue with many different makes and they do not have a software or Firmware update and do not follow up with the customer!
Break2Fix
SOLVED: So I have a SoundBar A530 and a Curved UE55JU6500 having exact same issue cuts/drops out every so often on TV ARC (HDMI) channel, very fraustrating!
Anyway, A Firmware update on the SoundBar only fixed my issue, I have used the USB method, simply follow the link to download the neccessary file to a USB stick and plug into your soundbar usb port, follow the instructions to get the fireware updated for you model types by clicking on this link <https://www.samsung.com/us/support/downloads/?model=N0021435> , Hope that helps!
p.t yemzy
MJP123
Hi thank you for your reply unfortunately I do not have a USB port on my B&O Stage soundbar.
Samsung have given up replying to my requests for Help and the retailer  who sold the TV is next to useless!
I find it appalling that this issue is left unresolved and these products continue to be sold.
Nick_W1
2021 55” Frame TV and Sonos Beam gen 2 has the same issue.
rprop
I have the same exact issue and its worsening.  If anyone gets any updated news please update the board
poprock
Everything has been perfect for me since the firmware update in March. Completely solved the issues.
