Smart TV - ue43nu7095 questions
(Topic created on: 26-05-2020 09:08 AM)
Ifranckd_29004
I purchased a Samsung ue43nu7095 and have 2  questions re: its usage.
1. How can I use headphones or headset with it?
Haven't found any jack cable nor Bluetooth bundle within, what are my alternatives
2. Why did Disney + app just appear out of nowhere without me installing it?
Thanks!
2 REPLIES 2
TessM
Mastermind
Hi @Ifranckd_29004 ,
this TV doesn't come with a headphone jack port. In relation to Bluetooth, please follow these steps: from Settings, select Sound, and then select Sound Output. If the option Bluetooth Speaker List appears, then your TV supports Bluetooth.
If your TV does not support Bluetooth but you still want to connect a Bluetooth speaker or headphones, you can get a Bluetooth adapter. These can be connected to a 3.5mm audio port or a standard left/right AUX audio port (red and white cables).
Are you able to tell me where is the app appearing as this shouldn't be on the TV if you haven't downloaded it?
Ifranckd_29004
Hi
I didn't find any Bluetooth option in Outputs.
Secondly, I don't have any jack no rca output.
Any idea of other options to use headphones or headset?
Disney+ appeared in Apps tab, without any manual intervention. When clicked on it, it opened the app without installing it, so it means app was previously installed.
Thus I just disabled internet on the smarttv coz I want to choose what it does and not have smarttv do anything without my approval
