Smart tv freezing after I open the pen drive
(Topic created on: 24-04-2020 05:05 PM)
Homer1988
Hy
I have  a problem of my samsung smart tv.
When I plug on the usb and try to select/open something from the pen drive, the smart tv collapse and restart itself.
My tv type:UE46H6203AWXXH (It's not a new tv)
The software is the latest. And I tryed to  reinstall the smart hub. No progress.....
Thank You for the help in advance.
Homer Jay Simpson
3 REPLIES 3
TessM
Mastermind
Hi @Homer1988 ,
let's have a look into this together. Have you been able to use this on your TV before? Do you have any external devices connected to the Tv and what kind of USB are you using?
Homer1988
Hy,
I have two Star Wars themed pen drive. An r2-d2 and a bb8. Both worked well. The starnge thing is that 2 days ago this happened only one of them. And the other one worked well. I thought the pen drive is broken. But the next day this happened with the other one too. I tried to reconfigurate the pen drive (exFat,ntfs) but no progress. Today I tryed my LG external storage. It works, but maybe one or two day later the situation will be the same with that. I will write an update a few days later.
Homer
ChrisM
SuperStar
We'll look forward to your response, @Homer1988.
