Go to solution Solved
Smart Tivi Samsung Q65R doesn't support mt2s movie file's sound
(Topic created on: 01-11-2019 11:08 AM)
phucan0112
Hi guys, i did buy Samsung Q65R . The tv link is here.
Currently, i did download some 4K movies or Full HD Movie which have name like this :1080p BluRay REMUX AVC DTS-HD MA 7.1.
When i connect the USB with the TV. I can open the movie file but it always said something like : The sound format is not supported. The subtitle files are working well, the only problems is that i couldn't hear to the movie sounds.
Anyone has any ideas how to fix this problems or just because the TV doesn't support the file.
Btw, the movie files have m2ts format.
AndrewL
@phuncan0112: As this is a non-EU model I am limited in the support I can provide, however you can find a list of supported audio and video codecs by checking the link below and scrolling to page 151 onward.
http://downloadcenter.samsung.com/content/UM/201909/20190905105602841/MUSDVBADR-4.0.0_EM_MUSE_ASIA_V...
I can see .m2ts listed, therefore there must be another issue with the file that isn't supported by the TV.
2 REPLIES 2
AndrewL
phucan0112
@AndrewL: I did find that Samsung has no longer support DTS HD audio codec which leads to the problem.
Thank you for your support.
