Samsung UE50TU7100 TV
(Topic created on: 28-11-2020 01:32 PM)
LindyGirl
Hi, I have just bought a Samsung UE50TU7100 TV and a Sanus Pedastel Stand to replace the Plastic feet on the TV.  Can anybody on here let me know if it's ok to fit the Stand's Horizontal bars directly to the back of the tv without using spacers. The top two vesa holes have 3mm spacers pre-fitted to the tv and there is no problem with them. The bottom holes do not. I am a bit hessitant because the plastic back of the television is slightly Bowed between the two bottom holes and I  can't decide if it is just the plastic and would pull in when I tighten the brackets or if it is the shape of the actual tv and I could damage it.
I hope this makes sense.
Thanks.
0 REPLIES 0
