Go to solution Solved
Connecting headphones
(Topic created on: 28-11-2020 01:33 PM)
Georgelisle
Trying to connect wired headphones to Samsung smart tv. There is no headphone Jack.  I have used an adaptor connected to red/white AV Jacks but still no success. Any suggestions?
DUMITRU79
Troubleshooter
Well , if i knew from the start at least the model , we could have avoided this . Can you get an optical cable and plug it in the adapter box and the other end in your TV ?
28 REPLIES 28
DUMITRU79
Troubleshooter
What type of TV do you have ?
DUMITRU79
Troubleshooter
Can you provide a TV model ?
Georgelisle
The box just says Samsung Smart TV 32”
DUMITRU79
Troubleshooter
Right...let's try another approach : what connections are available on the back of your TV ?
DUMITRU79
Troubleshooter
Does your TV set have BLUETOOTH ?
Georgelisle
Don’t look like it has Bluetooth. Sorry if I’m being vague but it was bought for me
Georgelisle
Ok so it’s got LAN, Video (green), Audio (red & white), Ant In, Optical and 2 other connections that I’m not sure of which are red and blue. I hope that makes sense
DUMITRU79
Troubleshooter
I would say this would be appropriate for the inputs you have on your TV
https://www.argos.co.uk/product/8686828?istCompanyId=a74d8886-5df9-4baa-b776-166b3bf9111c&istFeedId=...
DUMITRU79
Troubleshooter
Don't worry about it 👍 .
Basically you need an "digital to analog converter " . I don't think it matters which brand
