Samsung Tv
(Topic created on: 22-03-2023 05:17 PM)
ASP1
My Tv has started turning itself on/off. I get sound for around 5 seconds with no picture then turns off, then back on again around 10 seconds later doing the same and can repeatedly do this for hours. Any ideas?
6 REPLIES 6
nowdeleted
Big Cheese
Is the battery's in the remote fully charged?? also are any buttons jammed down ??
AndrewL
@ASP1: Please can you confirm the model number of your TV, located on the sticker on the back of the device (next to the reference 'S/N')? In the meantime, please try unplugging the TV at the wall for 30 seconds, then plug it back in to see if this helps.
ASP1
Handset is all ok.
ASP1
Unplugging makes no difference. TV tries to turn in. I get sound but no picture and does every 5 to 10 seconds 
AndrewL
@ASP1: If you press the Menu or Volume buttons on your remote, does anything appear on screen? Is the standby light flashing, or constantly lit when the issue occurs?
ASP1
Volume adjusts but no image or menus when I press any other button. Standby light flashes intermittently
