Samsung Tv plus subtitle
(Topic created on: 29-09-2023 08:54 PM)
Cristian74047304
Hi
Can you activate english subtitle on Samsung Tv plus when watching movies? I cannot!
3 REPLIES 3
AsadM
Hi @Cristian74047304, you can enable subtitles on your Samsung TV Plus by going into Samsung TV Plus > Go onto any programme/channel > Press the down arrow on your remote control > Settings cog > Caption > Tap on the dot on the right-hand side of 'Caption' to enable this. The dot will turn blue.
Cristian74047304
Hi
Thanks for the answer but that was the first thing I did, I mean…
I was trying to watch a movie with a subtitle, don’t wanna wake up the kids. The correct answer is: movies on Samsung Plus UK don’t have subtitle, I was able to find a movie from the 70’ that had one but the new ones don’t have.
thanks anyway, won’t watch Samsung Plus again
TV351
There must have been an update of Mountian Men show isn't streaming the subtitles. The up/ down arrows are not doing what they used to do.
