Samsung tv picture jumping
(Topic created on: 10-10-2023 07:20 PM)
Balfy
Hi my tv is constantly flickering, it does it during picture tests while factory resetting  it happens when nothing is plugged into the usb/hdmi slots as well as when things are plugged in. Ive updated software, changing eco solution and resetting the tv
any ideas or is the tv done for?
2 REPLIES 2
MorningBlunt
Troubleshooter
Looks like something is done for, ain't no fixing that with software alone.
MB
JAMES4578
Samsung Members Star ★★
Hi @Balfy you  could check all cables and connections to ensure everything is secure. If so press and hold in Power Button for 5 seconds or so to reboot until you see the Samsung logo. If does not solve the issue unplug at mains for around 5 minutes . However if errors  on  Picture Test after Troubleshooting , Settings-support-Self Diagnosis- Picture Test suggests a hardware issue and would need to get in touch with Samsung Support for advice.   However from the firmware it seems your Tv is  a 2018 model so a repair may not be the best option.
