Samsung Smart TV - UE32T4307AK - Wall Mount Screws Needed
(Topic created on: 13-12-2020 03:46 PM)
Kimbals69
Hi all,
I need help.
I have just purchased a new Samsung 32" Smart TV Model UE32T4307AK.
The VESA Wall Mount holes are there, but every Mount I have purchased does not have the correct screws.
The instructions say I need 4x M4 26-28mm screws.
Where can these screws be purchased/obtained?
I have tried some M4 screws I do have, but even the screw diameter Samsung states  appears too wide for the tiny holes in the back of the TV.
Any assistance would be very welcome, even from Samsung, if they wish to respond.
7 REPLIES 7
KE12
Amazon. Screw fix . Asda living
Oldyellr
Does the wall mount include the correct screws, just too long? Use washers, or cut them down. That's what I had to do.
rod55
Went to screw fix needed depth of hole now how do you do that .asked on amazon said type of screw ordered wrong type .why not just give 4 screws in box
sukkib
I have the same problem 😕 help?
Chill1977
I have the same problem.
Any response from Samsung ?
Happy to supply pictures
Members_stLMfaC
Just buy the screws from ebay less than £4
Oldyellr
Ebay may take a week.  Amazon a day or two. No good if you're in the middle of mounting your TV.  If the kit has the right screws, just too long, just use washers or cut the screws down like I did above.  Or take a trip to your local hardware store.
