Go to solution Solved
Samsung QLED Q60A - SOUND EQUALISER GREYED OUT
(Topic created on: 23-04-2022 05:21 PM)
sleeper99
Just bought a Samsung QLED Q60A Smart TV and the sound needs more bass however in settings the sound equaliser is grey out - what am I doing wrong
sleeper99
all sorted now thanks
5 REPLIES 5
ChrisM
SuperStar
Hi @sleeper99
Could you confirm what source you're using when viewing the TV, or is this happening on all sources?
sleeper99
Briantvr
I’m having same problem, can I ask how you got it sorted
sleeper99
Sorry, I can't remember, I just was playing with all the different setting and it worked. Sorry I can't be more helful
Briantvr
I got it, I had my sound on amplify. If you change to standard sound it works. Thanks anyway 👍🏻
