16-02-2021 03:28 PM in
TVI have just bought a new Samsung Q60 75 inch. Every time I start Netflix it loads fine and lets me choose a program. Then after 1 minute or so it just closes and the TV goes back to terrestrial channels.
it is I place of my previous Samsung with Wired network which never had a problem. The same issue happens on WiFi.
anyone got a fix for this.
thanks
Andy
16-02-2021 04:26 PM in
TV16-02-2021 04:46 PM in
TVNot seeing a fix there. I have set DNS to 8.8.8.8 but it did not help.
I guess I will have to use the support function. I really don’t have the patience for them
thanks
16-02-2021 04:51 PM in
TV16-02-2021 04:54 PM in
TVTried that. Also did a complete reset on it.
the reset took forever and seemed to corrupt Disney+ for a while.
Maybe I will try again with the reset as the whole thing runs so slow trying to pull up menus
16-02-2021 04:58 PM in
TV16-02-2021 06:28 PM in
TVOk. So I reset the tv again and set everything up. It looks ok and is responding better.
I used the restore backup function last time. I think that might be what messed it up. This time I did it all manually.
now to get it to recognise the old sound bar correctly.
thanks for the replies.
16-02-2021 06:34 PM in
TV
