07-08-2018 11:31 AM - last edited 07-08-2018 03:44 PM
Hello,
I recently purchased the UE49MU7000 and a Sonos Beam. The Sonos Beam connects using HDMI ARC (and CEC / Anynet+). I have also paired some bluetooth headphones to the TV.
The problem I am having is that whenever I select to output the audio to my bluetooth headphones, within about 5 seconds the audio returns to the Sonos Beam. This happens every time. If I go and disable Anynet+ I no longer have this problem. However I don't want to disable Anynet+ as I use the Beam to control the TV.
Q1 - Is this a bug or is there a way to stop the audio from automatically switching back to the Beam? I don't know if this is linked to the auto-hdmi source input switching for video content but I am on the latest firmware version and cannot see any options to disable auto-detect hdmi
Q2 - On a separate note, is it possible to rename the ARC input from "Receiver(HDMI)"? The TV recognises the input source as 'Sonos Beam' but for the audio it uses the generic label.
Many thanks in advance
14-01-2021 11:07 AM
Samsung, please fix!
14-02-2021 08:08 AM
I have this problem on a Q60T but just checked my sw version and already on 1460 with no further updates available so they’ve certainly not fixed it on my model m
10-03-2021 04:36 PM
Samsung can't fix the problem with 3 years? Awsome
09-04-2021 02:46 AM
Same issue
03-09-2021 07:54 PM
Same problem. Looks like Samsung definitely doesn't care to fix this.
21-09-2021 08:24 AM
Same issue here on a new TV with latest software. (version says “2014”, which I thought was a Year and was a bit shocked that there was no later update than that. )
26-01-2023 11:20 PM
From 2018 to 2022 these problem doesn’t solved. Epic bag by Samsung. X-)
