04-01-2024 08:22 PM
I have just purchased a Samsung Frame 55” 2023 tv and would like some advice re connections into the One Connect box. I would like to connect a Virgin TiVo box, Sonos Arc and a PS4 and was just wondering which should be connected to which connection on the box?
04-01-2024 08:36 PM
@Greendazzer123 : I recommend that you connect the Sonos via HDMI eARC using the HDMI cable that came with the soundbar, the Virgin box via HDMI, and the PS4 via the HDMI gaming port (which is typically HDMI port 4, and supports HDMI 2.1).
