Samsun TV model UE 48 J 5200 AKXZT HEADPHONES CONNECTION
(Topic created on: 15-02-2017 05:56 AM)
Rubbershoes
I CAN NOT FIND ON TV SET THE CONNECTION PLUG FOR HEADPHONES
6 REPLIES 6
AntS
Hi Rubbershoes. :smileyhappy:
This help you at all?
Rubbershoes
Thanks for answer . The headphones jack does not fit into the TV socket for headphones as indicated by you on the picture
JessL
Voyager
Which headphones are you using?
Rubbershoes
sony CHG cordlessTMR-IF 24 OR with standard jack
KellyM
Helping Hand
If possible, can you provide a photo of the back of the TV and the headphone connection you're using?
What happens when you try to insert the headphone jack into the headphone socket? Please note that the socket may be a little stiff if it's the first time you're using it.
yashar1
:thumbs-up-sign-emoji-modifier-fitzpatrick-type:
