Go to solution Solved
Samsung UE55NU8000 Bluetooth issue
(Topic created on: 02-06-2024 02:51 PM)
Krakoos
Hi, the Bluetooth connection in my TV has gotten worse recently and is very inconsistent. The audio starts crackling for no reason. It happens to all of my headphones, I tested 5 different ones, so it is a problem with the TV. Also, it happens to all apps, like YouTube, Amazon, Disney, and Netflix or watching movies from HDD. The strange thing is that it started a couple of weeks ago. I've never had this problem before. There are no new devices around my TV that could potentially interfere with the signal. I think it may be an old, outdated Bluetooth-type issue, but can't be sure.
I found a suggestion that the Bluetooth transmitter may help. Is there something else I can test before I purchase one?
JAMES4578
Samsung Members Star ★★
@Krakoos  Do you have the latest firmware for your TV model?  Firstly I would suggest that you unlink the Devices  and reset the Tv via  Settings-Support-Device Care-Self Diagnosis-Reset. Another option may be Settings-General-Reset.     Afterwards try the Bluetooth process again.
2 REPLIES 2
JAMES4578
Krakoos
Thanks, James. I had the latest software, but looks like the TV reset helped.
