Go to solution Solved
S27E510C VGA/HDMI issue
(Topic created on: 10-05-2017 12:15 AM)
ConnorSalisbury
Hi,
I have a strange issue with this curved monitor (S27E510C) that I've never seen before.
Basically the monitor will display any device that isn't Windows (Android, PS4, Apple TV, TiVo Box) via HDMI, but it won't display any Windows device through HDMI (tried the PC, my own PC and 2 laptops), it will only display Windows via VGA.
If I plug in a PC/laptop via HDMI the screen just flashes between the analogue and HDMI sources and eventually goes into standby mode. I've spent a full day trying to troubleshoot this and I've made no progress.
Any tips please? Thanks in advance.
KellyM
Helping Hand
Hey @ConnorSalisbury,
Have you installed the relevant drivers to your PC? You can find them here, under the download section. Let us know how you get on.
3 REPLIES 3
KellyM
Helping Hand
naanuharsh
I am having the same issue. Not resolved after installing the drivers. Please help
JovinoValverde
I have a similar issue. A windows Laptop works via a direct HDMI connection, but when using the VGA to HDMI adapter for another laptop that does not have a HDMI connection, the display just blinks, nothing shows.
