Ru7470 tv constantly loses WiFi signal
(Topic created on: 28-06-2021 05:22 PM)
Jase7878
My ru7470 tv is constantly losing the network signal, WiFi works on every other device with no problems… any ideas on a solution
4 REPLIES 4
Pugs1957
SuperStar
First thing is to reboot your router as this can fix such issues. How good is the signal to the TV?
Jase7878
I have reset the router, switched the tv on and off but the problem continues, it works for a minute or two then loses signal, signal to the tv is fine
Pugs1957
SuperStar
OK, 2 things to try. 1. If you have one SSID, split them so you have one for 2.4Ghz and one for 5 Ghz. Try changing the WiFi channel.
tduk
TV and router on same frequency...
2.4ghz or 5ghz
