Q90T 2020 Sound Drop
(Topic created on: 14-01-2021 11:45 PM)
Eshammy
Can anyone help with this: I’ve noticed vain enough I bought the tv in November 2020, that when using the apps such as a Netflix, Amazon Prime etc the sound drops off and becomes really quiet.
this isn’t the case when using ordinary tv/sky, both Standard and Amplified sound is great. Neither sound option works well when using the apps, which I find rather unusual. Does anyone know how to fix this?
4 REPLIES 4
ChrisM
SuperStar
Hi @Eshammy
What's the full model code and current software version of your TV? Go to Home > Settings > Support > About This TV.
Eshammy
Model: QE55Q90TATXXU
Software: T-NKMDEUC-1460.9, B0052200/B60202, BT - S
ChrisM
SuperStar
Thanks for that. Your TV is on the latest software. Let's try a Smart Hub Reset to see if that helps. Go to Home > Settings > Support > Self Diagnosis > Reset Smart Hub.
Let us know how you get on!
Eshammy
Hi, I ran the diagnosis and it all seems to be good. I also rest the smart hub but there is no change. The sound is still very quiet when using any of the apps.
