15-01-2021 11:25 AM in
TVHello All,
Need some help/ Advice please, My QE49R60 recently updated to the latest firmware 1374 from 1372, Now every time i power on the TV after about 10-30 seconds it tries to update, then we have to back out of the menu, like you would if you went in to the menus manually, Auto updates are off, done a reset. Going to have another reset when i'm in from work, but i'm not holding my breath.
Thanks for any help.
Tom.
Solved! Go to Solution.
15-01-2021 05:05 PM in
TV@Tom19681, Maybe you have update files on it ? Try unplugging USB memory and see if it helps.
15-01-2021 03:10 PM in
TV@Tom19681, Do you have USB memory connected to the TV ?
15-01-2021 04:44 PM in
TVHi, yes I do, a 1tb hard drive.
15-01-2021 06:26 PM in
TVHi Kamil,
Thanks for the heads up on the usb/hdd idea, like a fool i'd left the usb in the tv with the update files on!!!
Cheers,
Tom
