Sound drops after 1420 update on s90c with s800b!
(Topic created on: 13-06-2024 06:18 AM)
GalaxyNET
Hi, after update 1420 on my s90c tv with soundbar s800b, sound drops on wifi or tv + wifi. Please devs fix it soon and push fw update!
15 REPLIES 15
Max404
Exactly the same issue here!
AntS
Hi @GalaxyNET  and @Max404 ,
Can you share the full model code and software version that your S90Cs are on? (Menu > Settings > All Settings > Support >  About This TV. If you're sharing screenshot of that screen, make sure you block out the serial number.)
And have you checked for any software updates to your S800 soundbars?
GalaxyNET
IMG_0889.jpegNo soundbar fw update in smart things.
Max404
Hey,
No updates available for S800b sounbar.
TV model - QE65S90CATXXU
Software - T-PTMCDEUC-1420.9, E1371410, BT -S
AntS
Cheers @GalaxyNET  and @Max404!
Just to confirm: is this happening across all content and apps for you guys, or on anything specific?
GalaxyNET
Everywhere, Youtube, A1 TV box, Nintendo Switch, PS4
Max404
Yep. Everything.
GalaxyNET
With new update 1430.3 problem still exist, sound cuts off.
Scb1980
Same here. Sounds still Drops whe connected to soundbat.
