21-09-2019 04:18 PM in
TVDoes Samsung series 7 smart tv with airplay support airplay through QuickTime on Mac?
it works fine if I directly mirror then screen, but if I try the airplay function through QuickTime then it only shows the connect screen on tv and the movie won’t start in QuickTime on the Mac.
i have succedeed with typing the connection code and normal mirroring works fine
23-09-2019 02:14 AM in
TVI have noticed the same problem. When streaming through my old Apple TV, I found that playing directly from Quicktime (rather than mirroring the whole screen) provided much, much better streaming. Would be nice to see that feature supported natively by Samsung.
11-11-2019 03:55 PM in
TVI have the same issue with my Q90R TV. Mirroring the screen is so laggy. I would really love to see direct video playback support on the TV.
30-11-2019 02:56 AM in
TV30-11-2019 10:55 PM in
TVI have the same issue on a UE55RU7400 airplays just fine using youtube etc but won't play anything through quicktime player, really frustrating as most of what I want to airplay in the first place is through that particular player and all I get is the black airplay screen. Looks like are have to go back to using my apple tv box which kind of defeats the whole point of having airplay on the tv in the first place.
24-12-2019 09:48 PM in
TVSame issue on ue50ru7200u.
14-03-2020 03:52 PM in
TVSame issue with
I just have a 'connect to Samsung' screen my iPhone works perfectly, screen mirroring on all devices, seems like it may be a quick time issue, when I first used the TV it worked with QuickTime so I might need to back date my QuickTime, I'll report back if I have any luck.
14-03-2020 04:30 PM in
TV14-03-2020 06:12 PM in
TV14-03-2020 06:14 PM in
TVNot sure what movie formats will work in AppleTV app that can stream but .mp4 and .mkv don't work but .mp4 will play on you desktop
