Pairing headphones
(Topic created on: 20-08-2020 05:57 AM)
Mystery1
hello,
My model number is ue32t5300ak. How do I pair headphones? Either by blue tooth( not sure if tv has it), or manually
5 REPLIES 5
JAMES4578
Samsung Members Star ★★
@Mystery1 wrote:
hello,
Hi @Mystery1   Do you wish to connect Bluetooth headphones or wired ones?    Whilst this model does not support Bluetooth Directly https://www.samsung.com/uk/tvs/fullhdtv-t5300/UE32T5300AKXXU/#specs  you would be able to connect with a Bluetooth  Transmitter, https://www.headphonesty.com/2019/05/how-to-connect-wireless-headphones-to-tv/     Once set up the Sound  Output would need to be changed from Tv to Speaker List where the Headphones should appear but more details in link.
There is no Headphones  port so for wired Headphones you would need a  optical-to-analogue converter.
Information in this thread https://eu.community.samsung.com/t5/tv/where-is-the-audio-out-on-my-un55nu7100/td-p/790940
Mystery1
Cordless headphones. What are the options regarding cost and performance? Is the sv1770 and good?
JAMES4578
ok @Mystery1  Well the Sv1770 does get quite good reviews on Amazon, though some not satisfied. One comment was that usb power scource may not be powerful enough  (after one customer had problems)and to  try a mains power usb plug which may need an extension lead.
Basically prices seem to range from around £20-£65.   My Tv has Bluetooth Support and have not used the transmitters in thse links but would be worth looking into, others may be able to give you their experience.
https://www.headphonesty.com/2019/10/best-bluetooth-audio-transmitters-tv
https://www.interneteyes.co.uk/best-bluetooth-transmitter-for-tv-uk/
Mystery1
Thanks, only I'm really confused now as live chat says any Bluetooth adapter may not work? Is this correct or not?
What would be an alternative Samsung TV that already has Bluetooth?
What is the LG Customer service department like?
JAMES4578
@Mystery1  There is no guarantee but as far as I am aware a decent Bluetooth Adapter should work , see more here: https://www.techwalla.com/articles/how-to-add-bluetooth-to-a-tv
The 32 inch Frame has in built Bluetooth but is more expensive : https://www.samsung.com/uk/tvs/the-frame-lso3tb/
You may prefer a larger UHD TV  (43 inch)  if that would be convenient,  afew of these probably better value :
The TU7100 https://www.samsung.com/uk/tvs/uhdtv-tu7100/UE43TU7100KXXU/    and the TU8500 https://www.samsung.com/uk/tvs/uhdtv-tu8500/UE43TU8500UXXU/  for instance both have  Bluetooth built in.
Personally do not have experience of LG TV's and their customer service,  though varying experiences with different products https://uk.trustpilot.com/review/lg.co.uk  here:
