One Connect Box temperature
(Topic created on: 08-01-2022 11:36 AM)
Jezza1945
I have located my new One Connect Box in a drawer in a cabinet. I have cut out large ventilation holes on the floor and back of the drawer.  I believe that the ventilation is sufficient and the highest temperature measured on top of the box is 38c.  Is this ok, and if not what is the maximum it should be?
2 REPLIES 2
xSteveuk
Mastermind
Hi,
It may get warm as when in use but not get to hot could try below
For help
https://www.samsung.com/uk/support/contact/
Debiili
Sorry I can't help you with this, but this is something i have been trying to find out aswell. The operating temperature of my one connect box is actually 38 c too.
I too am however wondering what the maximum temperature should be.
