06-03-2025 06:00 AM
The speaker on my TU7000 TV would play fine for a while and then suddenly gives pulsating sound -- repeating the last audio sample repetitively. This happens with both a TV app or a streaming box, so it's not an HDMI problem. The firmware is 2601.1. I've tried a factory reset already.
Besides this problem, the TV also loses its WiFi MAC so it cannot connect to WiFi at all. I can at least work around it by using Ethernet. This seems to be an ongoing problem a year after I bought the TV, and seems to be a popular complain.
Solved! Go to Solution.
a month ago
My pulsating sound problem is unrelated to WiFi. But it seems to be gone after factory reset the TV (including powering it off for 30 seconds).
The separate WiFi problem, where the TV reports no MAC address, is still there. This problem happened before and after weeks or months, went away. I could work around it with an Ethernet/Wifi adapter. But since I use a Roku box anyway, there is really no point in have the TV connected to the Internet (and in fact to access my viewing habits), so I just forget about the WiFi.
Given these two problems, and the complicated remote control, I will never buy another Samsung TV.
06-03-2025 08:03 AM
Hi and welcome, WIFI seems to be the issue, is the WIFI signal weak, I use eARC HDMI so wired.
Also worth checking if you have WIFI entenders, I find with my music server the causes random issues, turns out the MACs are different.
2 Decades Samsung Ownership, If my response helps leave a Like and Accept as a Solution
DAILY: ZFold6, Watch Ultra, Fit3, CL Ace 2, BT-W6, 20,000 Power bank, Smart Tags
FAMILY: ZFlip5, ZFlip6, Watch6 Classic, Tab S8 Ultra, Tab S7 Plus, Buds Pro2, Buds3 Pro
OFFICE: Book2 Pro i7, M70A 32”, Logitech K700, MX Ego, M720 Triathlon, Pop, Jabra Evolve2
AV/GAMING: QN95A 50” TV, Q900A, SW900s, 8 Series TV, LG OLED, M70A 43”, Dell Inspiron G5
APPLIANCES: Jet 75 Vacuum, MC32 Oven, American Fridge, 8 Series TV, LG OLED
SPARES: ZFlip4, ZFlip3, Buds1 Pro, Buds2 Pro, Book2 Pro i5, Level Speaker
MAINTAIN: iPhone 14, iPad Air4, iPad Mini4, iPad Pro1 12.9, Watch6
a month ago
