25-10-2024 09:49 AM
I have recently purchased a Qe55595 tv & Q930 D sound bar. The problem is when turning them on I get no sound from the sound bar. Both TV & sound bar have power. To get sound I have to turn off both and power back up (sometimes 3-4 times) Occasionally sound will come on at 1st attempt.If I disconnect the sound bar and use the tv speakers no,problem. From what I understand the sound bar & TV should power on together. This should I also believe be a plug and play set up and link the soundbar & TV automatically. Is there somthing I am missing.
Solved! Go to Solution.
25-10-2024 10:07 AM
25-10-2024 10:07 AM
03-11-2024 12:02 PM
03-11-2024 02:10 PM
Had a link giving me some info on a link followed this and all seems good now
03-11-2024 02:21 PM
Wish the instructions that came with the sound bar and tv ve a clear link to this
