NEW TV WITH WAS0003 ERROR. #HELP
(Topic created on: 23-08-2018 08:39 AM)
I have this problem too
KasperIlse
Hey Everybody,
We just bought a brand new SAMSUNG UE43MU6100 smart-tv. We connected it to our Wi-fi and it worked perfectly fine.
It's a week old now and the internet just stopped connecting two days ago. It work on LAN-connection but no other Wi-Fi source.
When we reset the network and try again, it says it's 'connected but no internet'. We would like our tv to work on the Wi-Fi because of the cables. We tried to contact samsung via Facebook. They get you trough some steps. They all didn't work. (for example: putting the DNS to 8.8.8.8).
If we want to connect to some apps, we get: WAS0003 code.
Anybody else having this problem and knowing how to fix it? please HELP
Thank you!
3 REPLIES 3
paul1277
Black Belt
@KasperIlse wrote:
Hey Everybody,
Thank you!
First thing,  report it as a fault to your retailer,  as they are responsible under the consumer law,  not  Samsung and by the time you have messed about with them the magic 4 week period is over. If it worked and then stopped it sounds like a fault,  and even if a reset fixes it,  there is always it will fault again. You should not need to do factory resets on a new telly.  I would get it exchanged.
Paul
Tv38
How do you do a factory reset
JAMES4578
Samsung Members Star ★★
Hi @Tv38 ,  For modern models    Home -Settings - Support - Self Diagnosis - Reset
A Guide is here https://www.samsung.com/uk/support/tv-audio-video/Factory Reset
