05-10-2020 02:37 PM
I have samsung 43inch smart tv and a sound bar.
I connect the sound bar through bluetooth, so that multi output audio can work.
I witness that there is double sound. I tried digital output audio delay from 0, 50, 100, 150, 200, 250, but as a result nothing helps me.
Kindly help with this issue.
I also see that only optical is only audio output, why can't you use spdif, 3.5mm jack, 2male to 2 male audio output are not in audio output. this is a bad configuration.
