27-06-2022 02:13 PM in
TVTV does not connect to Internet. Just lost connectivity. Tried all solutions I can find but no good. Has anyone got any ideas
27-06-2022 03:16 PM in
TV@Wozp Could you let us know which steps you have already tried, please?
We will put a link below that includes troubleshooting steps that may be helpful here, unless you have already tried these-
28-06-2022 02:17 PM in
TVThanks for the quick response. Yep I've tried all the advice provided. Interesting where it says
I've rebooted the router, TV and reset settings, still no good. Sky box works fine
28-06-2022 04:06 PM in
TVModel no is
UE55NU8000
Software is
T-KTM2DEUC-1325.2,,BT-S
Thanks for your support
28-06-2022 04:51 PM in
TVWe can confirm that you're on the latest software version. Let's try a full reset of the TV. You just need to be aware that any changes you may have made to the settings, will be returned to the factory settings that the TV came with. Go to Home > Settings > Support > Self Diagnosis > Reset > Enter PIN.
28-06-2022 04:54 PM in
TVDone. No good still the same. Mac address and dns are blank
28-06-2022 05:12 PM in
TVMmm! The TV doesn't seem to be recognising the wireless signal coming from your router. As an exercise, are you able to try a wired connection, using an ethernet cable?
30-06-2022 12:10 PM in
TVNo I haven't got an ethanet cable. Have contacted my WiFi provider and they have tried something (I think splitting the frequencies so it's 2.4G) but still no good. The TV doesn't seem to want to reset, it's stuck on wireless but no option to set up router
08-07-2022 12:32 PM in
TVI got an ethernet cable and that gas found the router so ok. Haven't tried to reconfigure to wireless yet but will try later
