Internet connection problems
(Topic created on: 17-04-2020 08:32 PM)
Stevep13
I have a Samsung UE40D6100 led tv which I have had wired to my sky router, but when it's plugged in the wifi around the house doesn't work anymore but as soon as I unplug it's fine, have tried different ports and a new router from sky,  could this be a problem with the network card on tv or a software issue any help would be appreciated and other things to try
4 REPLIES 4
TessM
Mastermind
Hi @Stevep13 ,
I would be happy to have a look into this with you. have you tried to connect this using a different cable and would you be able to confirm which software version is the TV currently running on? The latest one available for it is the version 1028.0.
Stevep13
Hi thanks for reply,
yes have tried different network cables
and the software is 1028, guess as it's and older tv probably time for change unless anything else to try
ChrisM
SuperStar
his seems strange, @Stevep13. The fact you have your TV hard wired to your router shouldn't affect the Wi-Fi signal being given out by the router. Have you spoken to Sky directly regarding this?
Stevep13
I know it is a strange problem, yes spoke to sky and they replaced the router with a new one, and still no joy but as far as they say it's a faulty tv,
