How to Disable/Declutter Smart Hub
(Topic created on: 18-11-2024 10:37 AM)
kpalczynski
I have just received a new Frame TV (2024) as a warranty replacement, and despite my best efforts, I cannot configure it to function similarly to my previous model (2020). My old Frame TV had a bar at the bottom of the screen where I could select one of the streaming apps or input sources. On the current Frame TV, pressing the home button opens the Smart Hub in full screen. My installed apps are displayed as a row of postage stamp-sized icons, while the remaining screen area is filled with strips suggesting content from live streaming apps that I have already uninstalled and have no intention of using. Is it possible to restore the simple bar with just my installed apps or declutter the Smart Hub screen to remove this unnecessary content?
10 REPLIES 10
AndrewL
@kpalczynski: The Frame 2024 comes with Tizen 8, which features the new Smart Hub Home screen. It isn't possible to revert to the menu bar found in previous operating systems, however with time you should find the new menu layout intuitive. If you're looking for your installed apps, for instance, then navigate to 'Apps' (located towards the top of the screen).
To edit Apps in the 'For You' tab, navigate to the end of the list using the right direction button on the remote > Edit List > Move to an app  > Press the down direction arrow > Choose from the available options e.g. Move, Remove etc.
kpalczynski
So, there's no option to have a list of apps without encountering a list of thumbnails for all the episodes of Peppa Pig?
Thevofl
Does Samsung sell a dumb TV?  Seriously.  I don't want all that ***** on my TV screen when I am just switching between two inputs.  I don't care that you are recommending me Christmas movies or sports or news or or or or.  It is VERY counter intuitive.
Thevofl
Well after a week, the TV is going back to Costco.  VERY counterintuitive.
The_o
I have the same issue. I have the QN90C, and I'm struggling to find a solution. I bought an expensive TV just to see advertised content... I don't want any of this on my home screen. The icons of the installed apps need to be larger and have the option to remove the rest (popular films, suggestions for series, etc).
Members_qZsxlhi
Just adding my voice here. Please fix the cluttered smart hub screen, and also fix the omission of MyAlbum on Ambient Mode (OLED 2024 model)
my5c
Hi, the request is for decluttering Smart Hub from anything but what the owner likes. For example, I don't want to see anything related to apps I haven't installed. To me, not providing this option is a prevarication  against us paying users.
Samsung please let us customise our expensive devices as we see fit.
hub_hater
I HATE the Samsung hub. I just want to use my Xfinity remote and connect directly to my cable TV.  I have deleted every single app and my home screen is still filled with stuff I don't want to see. I don't want to see all the sponsored ***** on the Samsung home screen.
DTerry
I want to voice my strong disapproval of your Smart Hub.  This is an absolutely horrible user experience.  I do not want or need all the garbage for this recommrndation or channel and that app.  I want clean interface which contains only the options I choice to display.  You haven't even had the decency to allow the user to order the things that are their preferred apps to the top of the list.
Having been a software developer for more than 35 years I can't believe your interaction designers would even suggest such a horrific experience.
We always told our management that as they wanted something was as bad as they were going to get it.
This experience tops the worst or the worst.
Please fix it.  As it currently stands I can not and will not recommend any samsung devices with this UI/operating system.
